- Go to “https://www.dslreports.com/speedtest”
- Run a speed test for a 4G
It runs a speed test
Version 1.10.97 Chromium: 83.0.4103.116 (Official Build) (64-bit)
I know get a error returned from the site since the last Brave update:
This browser cannot reach all 10 local test servers error:7
Your browser failed to contact any of the candidate test servers that are known to be online.
Possible reasons:
- If you are using an older version of Chrome on a tablet or phone, disable “Bandwidth Management … Reduce Data Usage”. It has bugs.
- Your ISP DNS is slow. Try the non-https mode: http://www.dslreports.com/speedtest?httpsok=0 as it uses IP addresses.
- Your older browser does not support CORS (Cross Origin Request Syntax). Use a more recent browser.
- A browser extension is blocking the test. Disable the extension. (If you know what extension does this, please drop me an email using the address below)
- Anti-virus software is blocking the test.
- A buggy proxy, VPN, or web accelerator is blocking the test.
Nothing changed on my end, except Brave update. All still works fine with Chrome, FF, edge
