I think I have the correct category/label, right? I have an idea that when a tab plays sound and we have more than our allotted tabs set the parent tab indicator above the tabs should flash or do something when sound is playing from a tab within the parent group. I probably didn’t describe this as good as I could have but its as good as I could.
Related topics
| Prevent brave from muting a tab | 4 | 176 | March 5, 2025 | |
| Option to disable the speaker icon 🔊 in tabs | 0 | 584 | September 28, 2022 | |
| Remove the sound icon on a pinned tab | 1 | 747 | November 23, 2019 | |
| Tab playing audio has speaker icon - I go to mute it and it jumps aside for the X - I accidentally close the tab | 1 | 413 | March 5, 2024 | |
| Muting sound on tab incorrect behavior | 0 | 372 | May 17, 2022 | |
| Make muted tab icon persistent | 0 | 344 | May 7, 2022 | |
| Dark Color: 2 Changes to TAB Background / outline color 1) Active Tab 2) Sound output tab | 2 | 70 | September 10, 2025 | |
| Native implementation to increase/decrease tab audio volume per tab | 1 | 248 | July 25, 2025 |
