Sorting Bookmarks not working properly in side panel
With Bookmarks “open in side Panel” I am no longer able to do a “custom sort” with any reliable result. I think it worked well enough originally. Sorting A-Z and Z-A work as expected.
Discovered that if I do NOT open in the “side Panel”, I can as far as I tested, “drag and drop” in traditional Windows fashion to achieve the order I desire.
  1. Choose Bookmarks "Open “side Panel”
  2. Select “custom order”. Attempt to sort by either “drag and drop” or offered method.
Any selected attempt to move would result in expected action.
Brave is up to date
Version 1.78.97 Chromium: 136.0.7103.93 (Official Build) (64-bit)
Yeah looks like something broke in the last update or two. I’ve filed the following issue for this on our Github:
