I bought presale solaxy in my brave wallet. Connected it to the solaxy website and claimed my tokens. It shows up in solscan. And I added solx in my brave wallet, correctly I think. But it doesn’t show that I hold any solaxy tokens.
I’m having trouble adding as well let’s compare our information
Network Solana Main net beta
Token address CF2LNRPMCUXY8QKAYIAAPPGATUHGZKH3TPHMAEVE9ZLG
Name SOLAXY
Symbol. SOLX
Decimal 8
Does this look good ?
Here are instructions for adding tokens not available in the list of shown assets.
https://support.brave.app/hc/en-us/articles/20643855700109-Adding-a-Custom-Token
Thank you Evan ! I’m gonna give it a try and come back
Yes, we have gone through that process of adding solaxy, but it’s saying it failed to add the token. So that link is not helpful for us.
This is what I have for the “mint address” on solana network.
Cf2LnRpmcUxY8qkAyiaaPpgAtUHgzkH3tPhMAevE9zLg
Solaxy
SOLX
I used 9 decimals, but I don’t think that matters.
I was able to add 2 solaxy tokens to my asset list, but my solaxy is still not showing up. Because my token is tied to that mint address above. Even though I can clearly see my transaction on Solscan, it clearly shows going to my brave wallet address. It has to be a problem on brave wallet end.
I think I see the issue. It should be 6 decimals, not 9. Please try the following contract details:
Decimals: 6
Token name: Solaxy
Symbol: SOLX
Mazram, were you able to add the solaxy successfully?
You may need to delete the previous one that was added. I had no issue adding it just now.
Evan, I deleted all previous Solaxy tokens. I have tried all the details you provided. I must not be doing something correctly.
If you click the Visible Assets icon under Portfolio and search for Solaxy do you see any previous tokens appear?
@Mazram28 Are you still experiencing this issue as well?
Ok I just tried with the decimal value of 6 no luck I’m going to write down the mint address and physically type it to see if that works In a bit
I haven’t tried changing the decimal value I need to try today thanks for the info !!
Yea mine is still not working. I copied the address from Evan and used 6 decimals. No luck. It is the solana network we are using for it correct?
If you’re seeing Failed to add custom token it is likely there is already a token with the same contract address present. Try searching for SOL, SOLX, Solaxy in an attempt to identify any duplicates there were added incorrectly. Thanks!
I searched for SOLX, and Solaxy, nothing. Could it be that it’s not officially released? What am I missing here?
Hey Evan yea I tried everything you suggested I still can’t get the token in my wallet I Tripple checked the address and typed it manually and tried the different decimal points does it have something to do with Brave browser on iPhone ?
Evan, I am also having the same problem. Not sure what is going on. Surely somebody else on here is having the same problem. I’m curious to know why it added for you. I’m also on iPhone.
