Solaxy Presale Help
I purchased some presale tokens using Solana but cannot connect the transaction with Brave Wallet. I see the outgoing transaction, am able to locate the signature on solscan, but cannot figure out how to add it to the wallet.
Any suggestions?
Is the issue occurring on a specific network?
Solana
Version 1.77.100
Hello - You may need to add the token manually if you do not see it appear automatically.
https://support.brave.com/hc/en-us/articles/20643855700109-Adding-a-Custom-Token
Thanks for the response.
I did that but the purchase fails to show. Perhaps I am entering the incorrect address?
As noted, I can see the Transaction using Solscan. It includes the
–“transfer from” [proper address] (mine), links to the correct Solana account];
–transfer “to” with a [signature]. Is this key the one I need?
If not, how do I locate the proper one?
Again, many thanks for your kind help.
You mention a presale. Are you certain this token has been generated yet? Could you provide the token contract address?
Correct. It has not generated yet. But I understood that it could be managed from the Brave Wallet. Sorry for my confusion if not. First time doing presale on Brave.
Any suggestion on how to troubleshoot? Maybe not a Brave Wallet issue?
Again, thanks for your time.
If there’s no token contract yet, there’s no token to add to Brave Wallet. You’ll likely need to wait until the token generation event.
