I posted this problem back in March and it is still the same. If you try to trash any of those listed websites, there is no action or result.
289wk
July 1, 2022, 8:09am
2
@xida2001
The Brave Browser > Settings > Cookies brave://settings/cookies window says:
âSites that can always use cookiesâ
â
In order to assist others who may want to read about your issue, please edit the title topic for your issue, changing your:
âwebsites which are always allowed to use cookiesâ
to:
Thank you.
Just what the subject line says.
I click on the little garbage can icon, and nothing.
Brave team knows about this problem, they will eventually solve it.
Hi
The workaround is explained in many posts. Here is a summary for you:
First; Open brave://settings/cookies
Second open a second TAB: Type the url from the site under âSites that can always use cookiesâ, and open its page; Toggle ON/OFF the orange Brave shield icon for that page.
Check in brave://settings/cookies if the site disappeared. If necessary toggle again ON/OFF as above.
Result?
If not gone, you may have to delete the url in Preferences , but you have to be very careful! If you do try this, the first thing to begin with is to make a backup of the file Preferences . Hopefully, the steps above will resolve the issue.
Thx for that, but that is quiet some work, as there are so many sites to be deleted (either way, it works). But I think that really should taken care of by the programers
If you have hundreds, then maybe itâs because an app you have installed.
Is there some way to confirm if this bug is on the Devâs list? Would be good to know this bug is priority 1, even if there is no planned fix date.
chh_68
July 14, 2022, 9:52am
8
opened 10:47PM - 28 Oct 20 UTC
priority/P2
feature/settings
feature/shields/cookies
OS/Android
OS/Desktop
<!-- Have you searched for similar issues? Before submitting this issue, please ⌠check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
Sites cannot be deleted from the "always allow cookies" list, only added
## Steps to Reproduce
1. Add a site to "Sites that can always use cookies"
2. Try to click the "garbage" icon to delete a site
3. Nothing will happen
## Actual result:
Nothing occurs and the site remains
## Expected result:
The site should be deleted
## Reproduces how often:
Consistent
## Brave version (brave://version info)
1.16.68 Chromium: 86.0.4240.111 (Official Build) (64-bit) b8c36128a06ebad76af51591bfec980224db5522-refs/branch-heads/4240@{#1290}
## OS
Windows 10 64-bit
100 comments, Priority 2, brave team knows about this issue.
chh_68
August 3, 2022, 5:11pm
9
opened 02:42AM - 10 Mar 20 UTC
closed 09:34AM - 17 Jun 22 UTC
feature/shields
QA Pass-Win64
QA Pass-macOS
QA Pass-Linux
priority/P3
QA/Yes
release-notes/include
feature/cookies
feature/cookie-allow-list
OS/Desktop
QA/Test-All-Platforms
## Description
Delete button on brave://settings/content/cookies (under "allow⌠", which shows sites where the shield has been turned off), clicking the trash icon appears to do nothing.
1. Go to a site, bring the shield down for that site.
1. Go to brave://settings/content/cookies
1. Click the trash icon next to the allowed site.
## Actual result:
Nothing happens.
## Expected result:
Shields are brought back up for that site.
Every time.
1.6.59
## Version/Channel Information:
- Can you reproduce this issue with the current release? Unknown
- Can you reproduce this issue with the beta channel? Unknown
- Can you reproduce this issue with the dev channel? Yes
- Can you reproduce this issue with the nightly channel? Unknown
If this is an incompletely delivered feature, feel free to let me know and close this issue.
opened 03:46PM - 02 Aug 22 UTC
closed 02:31PM - 03 Aug 22 UTC
QA/No
release-notes/exclude
release-notes
OS/Desktop
### Release Notes
- Upgrade from Chromium 104.0.5112.69 to Chromium 104.0.51⌠12.81. ([#24364](https://github.com/brave/brave-browser/issues/24364))
- Farbled HTTP Accept-Language header does not have a q value. ([#24126](https://github.com/brave/brave-browser/issues/24126))
- Remove `Get image description from Brave` context menu option. ([#24047](https://github.com/brave/brave-browser/issues/24047))
- Browser crashes in SolanaProviderImpl::SelectedAccountChanged when trying to remove selected Ledger Solana account . ([#24046](https://github.com/brave/brave-browser/issues/24046))
- Extraneous data in eth_call response is not handled correctly. ([#23998](https://github.com/brave/brave-browser/issues/23998))
- [hackerone] wallet API freezing issue. ([#23973](https://github.com/brave/brave-browser/issues/23973))
- Errors listing NFTs on OpenSea. ([#23889](https://github.com/brave/brave-browser/issues/23889))
- Support using ledger hardware for Solana signTransaction, signAllTransactions provider APIs. ([#23842](https://github.com/brave/brave-browser/issues/23842))
- Broken Image for Solana on localhost. ([#23821](https://github.com/brave/brave-browser/issues/23821))
- Update search engine defaults for AT / ES / MX . ([#23814](https://github.com/brave/brave-browser/issues/23814))
- Set macOS minimum version to 10.13 for 1.42.x in Sparkle. ([#23748](https://github.com/brave/brave-browser/issues/23748))
- Add custom asset page not loading. ([#23694](https://github.com/brave/brave-browser/issues/23694))
- [hackerone] IPFS crash. ([#23646](https://github.com/brave/brave-browser/issues/23646))
- Add Loading Skeletons to Wallet Panel. ([#23577](https://github.com/brave/brave-browser/issues/23577))
- [hackerone] Add warning that local ipfs node will bypass browser proxy. ([#23570](https://github.com/brave/brave-browser/issues/23570))
- NEAR integration (Aurora). ([#23522](https://github.com/brave/brave-browser/issues/23522))
- Pinned tabs, when muted, can't always be unmuted by clicking on unmute icon. ([#23476](https://github.com/brave/brave-browser/issues/23476))
- Remove v1 shields UI (a.k.a. shields extension panel). ([#23285](https://github.com/brave/brave-browser/issues/23285))
- Enable 1PES by default. ([#23180](https://github.com/brave/brave-browser/issues/23180))
- Remove P3A protobuf reporting. ([#23147](https://github.com/brave/brave-browser/issues/23147))
- Add ability to debounce URLs based on a regex applied to the path. ([#23121](https://github.com/brave/brave-browser/issues/23121))
- Add setting to allow separate search engine usage for Private Window. ([#23091](https://github.com/brave/brave-browser/issues/23091))
- Add new setting to show/hide bookmarks and history from the address bar autocomplete results . ([#22948](https://github.com/brave/brave-browser/issues/22948))
- Wallet should use the user locale when displaying currency symbols. ([#22815](https://github.com/brave/brave-browser/issues/22815))
- Fix cosmetic filters not being applied inside of child frames. ([#22781](https://github.com/brave/brave-browser/issues/22781))
- Add localisation for tab-titles on add-switch chain dapps panel. ([#22672](https://github.com/brave/brave-browser/issues/22672))
- Evmos actions failing (such as voting). ([#22650](https://github.com/brave/brave-browser/issues/22650))
- Add link to support page within wallet. ([#22598](https://github.com/brave/brave-browser/issues/22598))
- Refresh design for NTP Private Window. ([#22566](https://github.com/brave/brave-browser/issues/22566))
- Bright flash of light upon opening a new tab. ([#16078](https://github.com/brave/brave-browser/issues/16078))
- Add list of well known chains to the local data files updater. ([#14574](https://github.com/brave/brave-browser/issues/14574))
- Import from Chromium version of Microsoft Edge. ([#13334](https://github.com/brave/brave-browser/issues/13334))
- Filter out Marketo's email tracker from URLs. ([#9018](https://github.com/brave/brave-browser/issues/9018))
- Delete icon in cookie settings does not delete some entries set from Shields or other settings. ([#8604](https://github.com/brave/brave-browser/issues/8604))
Seems to be solved, check it.
Yes this issue should now be resolved with the update to version 1.42.86.
Iâve just deleted and stopped using Brave after 2 years waiting for this to be fixed and constant crashes too, I canât take it anymore, literally a backlog of 3 different posts all closed on the forum without ever being fixed, so I donât see it getting fixed anytime soon
I mean come on, not being able to control which websites always get access to your cookies on a privacy orientated browser ? Sounds like a bad joke (I donât understand how it takes 2 years to make a trash button function?)
Iâm on Version 1.42.86 Chromium: 104.0.5112.81 (Official Build) (64-bit), still present, still not working
@davidtaylor ,
Can you share some example websites where youâre not allowed to clear the cookies from?
Hereâs my current list of sites which cannot be deleted (i.e. bin icon does nothing). Using version v1.42.88 (Aug 6th, 2022).
[*.]toptechjobs.com
embedded on www.toptechjobs.com
[*.]gr8people.eu
embedded on contractortalent.gr8people.eu
At Brighton YMCA, we offer housing and support to single men and women in housing need and help them improve their wellbeing, gain skills and maximise their confidence so that they can go on to live independent and fulfilling lives.
Estimated reading time: 2 minutes
Including third-party cookies on this site
update-details.santander.co.uk
retail.santander.co.uk
Search the world's information, including webpages, images, videos and more. Google has many special features to help you find exactly what you're looking for.
Decentraland is a virtual social platform built and governed by its users. Every day, users enter the world to meet up, play games, attend live events, trade in the marketplace, engage with brands, visit galleries and much more
www.youronlinechoices.com
Thank you for the information. Passing this along to the team now for review.
@MrPassey additionally, were these cookies added/blocked by Shields, or were these manually added by you to the list?
I didnât add them manually, so must have been added automatically by the shield.
