The share page with function on the iOS app rarely works properly. It constantly tries to share the previous webpage or two that you were on instead of the current address. More often than not, I have to copy the link from the URL bar instead of using the built in function. Very annoying.
@dz2106 ,
Welcome and thank you for reporting.
This issue is known and has received a fix that should be pushed into the next browser update:
opened 08:38PM - 31 Jan 21 UTC
closed 02:46PM - 05 May 21 UTC
Epic: UI/UX
QA/Yes
bug
release-notes/include
<!-- Have you searched for similar issues on the repository?
Before submitting … this issue, please visit our wiki for common ones: https://github.com/brave/browser-ios/wiki
For more, check out our community site: https://community.brave.app/ -->
### Description:
Sharing a URL for the current page, using the same tab that was used to previously share a different page’s URL, will result in the original URL being shared.
### Steps to Reproduce
1. Open the three dot menu from any page
2. Tap “Share with...”
3. Either share the page or close out of the share window
4. In the same tab, navigate to another website
5. Using steps 1-3, attempt to share the page
6. Observe the link being shared
**Actual result:** Link shared the second time is the same as the first link.
Screenshot of issue: https://imgur.com/a/AA3xRbb
**Expected result:**
Link shared the second time is for the second page shared.
**Reproduces how often:** [Easily reproduced, Intermittent Issue]
Always reproducible
**Brave Version:** Version 1.22.2 (21.1.21.11)
**Device details:** iPhone 12 Pro Max, iOS 14.4
**Website problems only:**
- did you check with Brave Shields down?
- did you check in Safari/Firefox (WkWebView-based browsers)?
N/A
### Additional Information
Awesome thanks! I just wanted to call it out in case no one else did. Glad to get more involved though!
