Websites create the same fingerprint ID even though ‘Block Fingerprinting’ is set to Standard or Strict.
However if the ‘Font Fingerprint Defender’ extension is installed, a different fingerprint ID is generated every time a webpage is refreshed, which is what I would expect.
- Switch on Block Fingerprinting under Settings > Shields (either Standard or Strict)
- Go to https://webbrowsertools.com/
- Select any of the four fingerprint tools (Font, Canvas, WebGL or Audio)
- Note the value of the displayed Fingerprint ID
- Click refresh (or close tab and repeat steps) and compare with the ‘new’ Fingerprint ID
- Install and activate the ‘Font Fingerprint Defender’ extension
- Repeat steps 2-5 (testing with Font option). Now the fingerprint ID changes each time
Same fingerprint ID
Different fingerprint ids when refresh the page
When Block Fingerprinting is switched on (Standard/Strict)
[Version 1.61.109 Chromium: 120.0.6099.144 (Official Build) (64-bit)]
