Briefly describe your issue:
Rewards are not arriving for a couple of months. Neither from PC, neither from MacOS, neither from Android device.
What Operating System and Brave version are you using? (Menu --> About Brave)
Latest ones on PC, MacOS and Android. Problem was present on previous versions also.
Who is your verified custodian? (Uphold/Gemini/bitFlyer)
Uphold
Yes
