Reward not send me please help me
Briefly describe your issue:
Answer: I am using Anroid 12
Is your Brave Rewards Profile currently verified? (yes/no)
Answer : No
Dot not Remember also one years
Yes
Are you using a VPN? (yes/no)
No
Yes . I am live in turkey
No.
Have you manually turned off Auto-contribute on all of your devices?
yes
Hello, I haven’t been able to receive Brave Rewards for about 3 months. I click on the “Request” button, but I get the message “Oh, something went wrong”. and the “request” button comes into the mix again, I click the “request” button again. And I’m getting the “Oops, something went wrong” warning again and this process continues again. Can you help me?
@EmrahG You didn’t answer this.
If you actually tried this and that didn’t work, then most likely is your issue. Your Android device must pass SafetyNet. If it doesn’t, then you can’t get Rewards.
