I haven't receive brave rewards for 3 months in my android device
Is your browser wallet currently verified? (no)
Have you been able to successfully receive payments in the past?(yes)
Are you using a VPN? (no)
Are you in a supported region (see here for list of supported regions)?(yes/India)
Does your device pass the SafteyNet check (Android only)?(yes)
Hi
@kent09 Submit a request by filling the form @ adress below and sending it to Brave employees. Keep post open.
