The web that I have problems to run is this
I tested with Edge an work fine, also test in an privacy mode and also works fine, so I don’t sure what is the problem to run this web in the clasic mode of Brave.
@hanu,
It works in Edge and in Private mode because one of the extensions you have installed is likely interfering with the page. On my end, the site loads without issue in Brave stable:
Can you try disabling (at least temporarily) any extensions you have installed and see if this helps resolve the issue?
