@Mattches @clifton Problem in the site on PC https://www.sarkariresult.com/
Brave screenshot with shields on (tried with shields off too)
Chrome works great…see screenshot
Looks OK to me - do you mind trying a force-reload? On Windows, this would be done using Ctrl + Shift + R (macOS is Cmd + Shift + R)
Looks okay here also, no overflow issues. Yeah would agree, force a refresh
I did all that, but it looks like my brave wouldnt render it correctly.I restarted my laptop,cleared chache,deleted temprary files…everything but still no luck.
if you want any info for troubleshooting, please let me know
Does changing the font size help? <ctrl - >
NO, it didn’t help
@anujkmr953,
This site works just fine for me – can you please try this in a new profile and see if you get the same results?
In new profile it works fine. So how to fix the existing problematic profile?
@anujkmr953,
Have you tried clearing your cache/browser data for All time range?
clearing cache of all time didnt fix it
@anujkmr953,
Any extensions installed in your main profile? Also, can you go to the site, open the dev tools console window (Menu --> More tools --> Developer tools --> Console), then try clicking on a link and sharing a screenshot of any output from the console window here?
Can you check the same page in Chrome?
Not sure tbh.
i cant replicate it.
shields dont affect it.
new brave profile works fine.
I just wanted to fix the current profile.
By the way thanks for helping.If you find any solution in the future please tell me.
I uninstalled and reinstalled brave.It feels so fresh !
…and it fixed the issue.
