Proxy request help
Not sure if this was addressed I’ve tried to search also, looking to see how I can manually add a proxy?
Hello, @Yaks. Can you elaborate on your need? Typically you would configure a proxy at the system level. You can access that region of the OS from within the Settings of Brave:
Yes that I see, but we’re is that on the mobile app?
I’m sorry, which mobile app? iOS or Android? This isn’t configured within the browser; it’s usually handled within the Wi-Fi portion of your OS Settings.
Android would like to configure it
https://duckduckgo.com/?q=configure+proxy+android :slightly_smiling_face:
