Problemas con el Panel de Personalización
Me es imposible agregar un site en las pestañas favoritas. Puedo borrarlas, pero agregar no responde, reinicie Brave, sin exito. Alguien ayuda?
Translated via deepl.com
TITLE:
Problems with the Customization Panel
CONTENT / DESCRIPTION:
It is impossible for me to add a site in the favorite tabs. I can delete them, but add does not respond, I restarted Brave, without success. Anybody help?
@magela08
Please edit your Original Post, in order to include:
(Por favor, edite su Post Original, con el fin de incluir:)
  • Brave Browser version numbers
  • (Números de versión del navegador Brave)
  • Operating System version numbers
  • (Números de versión del sistema operativo)
v1.76.81
Windows 10
May be helpful info:
Add to the favorites" option has disappeared - #4 by Mattches
the option will not appear if the site is already added to favorites — can you confirm whether or not this is the case for you?
Simply visit a site that is not already part of your favorites and see if the option appears in the menu.
thanks,the problem solved itself.
