Problem with extensions - not working
Today i received message about disabled extensions
History AutoDelete
Tab Count
how to downgrade to extensions back to work & block updates
Brave Version( check About Brave): 1.92.134 (150.0.7871.63)
@Zlotowinfo
Some extensions suddenly turned off because they are "no longer supported" - #21 by 289wk
Some extensions suddenly turned off because they are "no longer supported" - #23 by 289wk
Why is brave removing uBlock? - #4 by 289wk
Let me help. Based on my research and testing, I’ve found a way to install the MV2 extension on Brave (Chromium 150). It may not be the official method, but this approach can help restore MV2 functionality in Brave. Please read the guide I’ve posted below. In my opinion, History AutoDelete can be enabled using this method. I hope this helps.
