Problem when playing videos
*Description of the issue:
Hello there, having trouble when playing videos in various websites (i.e Youtube, Vimeo) since last update. It loads the sound but no video. When I scroll up or downthe box where the video is supposed to be a “moire pattern” appears all the time (can’t upload a screenshot to actualy show how this looks like)
  1. Just enter the websites
Play videos with both images and sound.
[Versión 1.31.91 Chromium: 95.0.4638.69 (Build oficial) (64 bits)]
Windows 10.
Didn’t add any extensions.
Thank you!!
Does the issue occur in a Private window?
Does the issue occur if you create a new profile and try it in that profile?
Is Hardware Acceleration enabled in Settings? (“Use hardware acceleration when available”) If so, try disabling it, does it change?
Tried disabling “use hardware acceleration when available” and worked! Thank you so much! :slight_smile:
