Description of the issue: Printing fails using Brave print Dialogue in Ubuntu 24.04LTS
1. Select a document in Brave (source not relevant – may be an attachment, web page or email)
2. Invoke Print dialogue
3 Use default printer as already selected in Destination (printer is visible via CUPS 2.4.7 and responds to options chosen in the Dialogue)
4. Click Print button and release
First print in a Brave session prints
Subsequent prints fail silently unless I click and HOLD the Print button for > 10 seconds (approx)
Expected result: Document prints on selected printer
Reproduces how often: Every time, but see above
Ubuntu 24.04LTS
Version 1.88.134 Official build 64-bit
Chromium 146.0.7680.153
Last updated 23 March 2026
Problem predates latest versions
Reproducible on current live release (yes/no): Not sure what “current live release” means
Printer is Brother MFC-L2700DW series configured in CUPS as Driverless 2.0.0
Save as PDF works correctly every time
Problem does not occur if I select Print Using System Dialogue (Control-Shift-P)
Problem does not occur if I deliberately re-select the printer using Destination drop down, then proceed to step 4 above
Found a similar bug report at https://community.brave.app/t/printing-fails-on-ubuntu/647944 but it closed before I could respond and some aspects did not correspond to my symptoms
