Popup blocker opens a popup 🙃
I have strict adblocking and tracking protection activated and each time Brave blocks a popup malicious website it shows a popup tab to tell it has been blocked instead.
Is there any option to disable such messages ?
I don’t have any URL to show you cause it happends randomly, but I think it happens when websites are using clickjacking to open popups.
@Pol it is popping up to let you know something tried to open it. If it was being blocked, it wouldn’t get that far. You asking to disable that notice means you’d like it to just immediately open the harmful content?
What you should do is provide details of where you’re at when these things appear. And if it’s not on any particular website you’re visiting, then it sounds like you have malware/adware or a virus and you should do a full scan of your device.
Which site is coming from? Gathering its a streaming/download site I take it?
“You asking to disable that notice means you’d like it to just immediately open the harmful content?”
No, I’m asking that it just immediately DOESN’T open the harmful conten :stuck_out_tongue:
For exemple it could just show a discreet notification that a page has been blocked, and if you click on it, it could then open the tab shown in the screenshot
