I want to inform you that playlist doesn’t work anymore. Can you fix it.
What OS and Brave version are you on? Can you describe your issue in more detail? Thank you!
I have iphone 14 pro max with ios 16.4.1 firmware. I want to add music on playlist but doesn’t play it on the playlist. And I can’t delete old music from the playlist.
@Jenna1 is this still an issue for you? Can you confirm what version of Brave you’re using?
