In a Brave Browser New Window, go to: brave://policy and enable the âShow policies with no value setâ checkbox:
That allows you to see both the set, and the un-set, policies - the status of policies. For more info, this issue requires careful study of 2 websites:
At the Brave Support link, I suggest that you download the Brave Policy Templates (âpolicy_templates.zipâ) file: âhttps://brave-browser-downloads.s3.brave.com/latest/policy_templates.zipâ
Expand that file. You will get a folder named âpolicy_templatesâ. Therein, open the âwindowsâ folder. Therein, open the âadmâ folder. Therein, open the âen-USâ folder. You can then open the âbrave.admâ file, by using a text editor.
The âbrave.admâ file is large, with a lot of information â please do not panic. Search in that file, for âBlockExternalExtensionsâ You should find the following section - notice the âVALUEONâ and âVALUEOFFâ numeric values:
The VALUEON numerical value of 1 means âtrueâ and also means âenabledâ.
The VALUEOFF numerical value of 0 means âfalseâ and also means âdisabledâ.
Now, at the Google Group Policies (âChrome Enterprise policy listâ) website, search for âBlockExternalExtensionsâ . . . you should be able to find the section:
There, you can read about âBlockExternalExtensionsâ and âBlocks external extensions from being installedâ >
- âSetting this policy to Enabled blocks external extensions from being installed.â
- âSetting this policy to Disabled or leaving it unset allows external extensions to be installed.â
On a Windows OS machine, you may be able to use the âLocal Group Policy Editorâ mentioned at the Brave Support link. [I do not have a Windows OS machine handy, to run thru the steps.]
All the above, is a lesson on how to block a change of a Brave Browser feature/setting; and, an introduction to Brave Browser Group Policy settings.
You should back up your Windows OS Registry before editing any setting therein. You can also make a text version of the Windows OS Registry backup â handy for searching and future reference.
