Picture in Picture lost focus when should be always on front
Description of the issue: Since a couple of months I realized that Brave Explore lost the always on front feature when the picture in picture is activated. As far as I know, this behavior only happens in Ubuntu. In Windows the picture in picture works fine, as expected (always on front). Does anyone know what could have happened?
  1. Play any video
  2. Activate the Picture in Picture
  3. Change to another app or window and the focus on the PiP is lost
Expected result: The PiP should be always on front
Brave Version( check About Brave): Brave 1.86.142 (Official Build) (64-bit) ; Chromium: 144.0.7559.97
Additional Information: My linux distro is Ubuntu 24.04.3 LTS
After searching on Google, I found this workaround: press Alt + Space while the PiP window is active to open the window menu, then select “Always on Top”. This isn’t permanent, it’s necessary to apply this WA on every tab or video you want to see on PiP. As I can remember, this wasn’t the usual behavior until a few months ago.
