Permanent disable block trackers and advertisement not possible?
Hello,
I would like to disable the above mentioned global shields feature permanent. But every time i reboot the browser it enables itself again??
I prefer to disable it, and use umatrix and ublock instead.
Is this by design, or is this a possible glitch?
V1.28.106
It is possible, but there is a known bug that clearing Site and Shields Settings resets global Brave Shields settings, so check the following:
  1. Open brave://settings/clearBrowserData.
  2. Click on On exit.
  3. Make sure Site and Shields Settings is not selected.
Thanks. I had Site and Shields Settings on exit enabled.
Now it’s working.
You’re welcome!
If you would like, you can track the progress of fixing the aforementioned bug over here:
