Unable to change Microphone permission settings for individual, local site. When looking at the permissions for the site specifically, several options cant be changed such as Camera perm or Microphone permissions but other options are changeable (Solana, Images, Sound etc)
When using any remote site with a FQD address, I will get a pop up asking to allow microphone access (like google hangouts). Click ok and that works as intended.
When connecting to a local ip or non FQD, no popup asking for access. It does however give the error that the browser does not have access to the microphone, please change settings in browser.
Alert stating no access:
Site specific permissions: options in blue square are immutable, cannot be change from this screen. Options above and below are changeable. Reset to default with same problem. Created a new profile, disabled all extensions, turned off safe browsing, turned off shields for this site, allowed cookies and fingerprinting. Relaunched browser and options are still locked out. Tried a private window and tried using the ip instead of a hostname, still unable to change mic options. Reset permissions from that screen, same issue.
When trying the local IP without the port it does allow me to change microphone permissions
When adding the port, the site specific options are immutable again and stuck at blocked.
Should be able to change microphone access for a local web page but the options are not changeable, no drop down.
Every time I visit the local site. FQD remote sites, even with a port added work as intended, options are changeable.
Brave is up to date
Brave 1.79.119 (Official Build) (64-bit)
Chromium: 137.0.7151.68
| Edition | Windows 10 Pro |
| Version | 2009 |
| Installed on | 8/16/2023 |
| OS Build | 19045.5965 |
Anythingllm (10.10.10.131:3001) is a ‘web interface’ for communicating with AI LLM’s if that makes a difference.
Love Brave, this is very strange but perhaps I’m missing something easy? Also tried Brave (latest) 1.79.119 on Ubuntu 22.04 with the exact same issues.
Thanks
