My tabs keep disappearing and reappearing
Hello,
On my Poco phone (Android) I’ve been using Brave browser here I had a lots of tabs opened. On day, all of a sudden, all my tabs disappeared, so I forgot about them and opened a bunch of new ones. After a month or so, these new tabs were replaced by the ones that previously disappeared. Again, after a few months they disappeared and the tabs from the second batch showed up. And so on for like 2 or 3 more times.
It’s very weird. I didn’t find any pattern why this happens (update of Brave, phone, restart,…), it just happens out of nowhere. Did this happen to you as well? Do you know why or how to fix it, please?
Thank you
Android 14
Brave 1.77.101
@ericson1998
Searching the Brave Community:
Lost Tabs issues:
-https://community.brave.app/search?q=lost%20tabs%20in%3Atitle%20order%3Alatest
Sync and Tabs issues:
-https://community.brave.app/search?q=sync%20tabs%20in%3Atitle%20order%3Alatest
Consider an Android tab management extension; and also consider what existing extensions might be a source of trouble.
How to do a complete Exit / Quit of the Android device:
