My pinned tabs keep disappearing
UPDATE: 24 March: It’s still happening.
I have my start up settings set to ‘pick up where you left off’. I always close the browser properly, but the pinned tabs keep disappearing. This is a glitch that your techs need to resolve. It’s irritating.
Version 1.73.105 Chromium: 131.0.6778.265 (Official Build) (64-bit)
Same issue. For me, the problem is only with one profile. I was so ready to switch to Brave, but this type of glitch will leave me on Edge (metaphorically, too) until I see a definitive resolution (vs multiple years of the same report showing up on the community threads).
Same issue!! Please fix!!
I have had the pinned tabs disappear a couple of times in the last year or so. But this morning, all four of my windows 11 desktops, each of which has a separate group of apps including Brave, and each Brave had a long group of Tabs on the left side, all of which have been working fine for a long while, all disappeared when I restarted Windows. Huge headache, as the history buttons dont seem to gather the list of tabs, only the last opened. This is of course unacceptable and I hope to see an explanation from Brave or from someone in the support group. Thanks.
Can anyone here seeing this behavior please confirm the browser version and OS they’re using when this issue occurred?
My Brave version is Version 1.74.50 Chromium: 132.0.6834.111
I am on a MS Surface running Windows 11. As I see the same conversations over a few years with this problem, without a serious reply from Brave support, I will consider dropping Brave.
