I have three monitors and am using the Nvidia surround configuration. So in other words the three monitors are acting like one big one. Quite frequently when I select my toolbar bookmarks the drop-down menu is not in its correct position. Either it is on the left flank or the right in a very difficult position to select my bookmark. Very annoying as most time I have to reboot to fix the issuse.
@BERN_017,
Can you share a screenshot of how it looks on your end when this happens? Additionally, can you please tell me what Brave version and OS you’re using?
