When I try to move a tab with drag and drop inside the opened window, the tab opens in a new window, instead of moving inside the tab list of the same window. It also happens in privacy mode and when I disable all extensions.
In a different profile on the same machine the drag and drop moving is still working.
Click a tab
Try to move it inside the window
I would expect the tab move inside the same window
Version 1.34.80 Chromium: 97.0.4692.71 (Offizieller Build) (64-Bit)
EDIT:
At some systems, but not all, @felipeiise solution seem to solve the problem:
Link to the post to like if it worked for you: LINK
HI there I am also having the same issue form about an hour. Can’t get it to working Manjaro with kernel version 5.14.21 Brave Version( check About Brave ):
Version 1.34.80 Chromium: 97.0.4692.71 (Official Build) (64-Bit)
Having this from when I turned my computer on from about 3 hours a ago. Restarted to no avail.
Not sure if anyone else has noticed that you actually can’t drag or drop anything in Brave after the latest update? You use to be able to drag websites into the bookmark bar as well, but that doesn’t seem to work any more either? Think I’m going to start using Opera instead.
Same here;
Brave version: 1.34.80 Chromium: 97.0.4692.71
Just realized how often I’m using drop and drag on tabs. Hoping there’ll be a Chromium version rollback soon until this is fixed.
felipeiise’s fix didn’t work for me either as of 12, Jan 2022.
“Use system title bar and borders” was not checked for me. As a test I turned it on, closed Brave, then opened it again, and unchecked it. Did not fix the issue.
This is honestly a huge issue in my workflow? I often have dozens of tabs open doing research for my job, and i like to sort and group them by windows. Not being able to drag tabs or rearrange tabs is a HUGE issue in my workflow.
I even specifically joined the support community so I could look up if there was a solution to this!
I’m on Kubuntu 21.20, Brave Version 1.34.80 Chromium: 97.0.4692.71 (Official Build) (64-bit)
This is not a solution for me. I am seeing that ALL “drag and drop” functionality in Brave 1.34.80 is non-functional on OpenSUSE KDE Plasma, even after turning off “Use system title bar and borders” and browser restart and reboot.
This means the Bookmarks page is broken, I can’t claim my monthly earned BAT because the “captcha” fails, and any website that uses drag and drop is broken.
UPDATE: the BETA version of Brave has the same problem – any kind of drag and drop does not work. Tried dragging bookmarks and bookmark folders and nothing happens.
