bug? : Not being able to move window with tabs open
idk how to report a bug, I looked thru all the links and spent way to much time searching for it, so I am posting it here, hoping it gets fixed.
When you have multiple tabs open and have the window dragged to the side. You can not drag it back, ie: there is no room to click on the bar to move it as the tabs are in the way.
So your stuck closing out the whole browser or dragging each tab out to close it as you try to move your main browser window.
Like we have 0-1 pixels to grab on to the whole window and not the tab.
Try it yourself, try to move the window that’s above the tab, its imposable. idk hay this has not been pointed out yet, but I hope it gets fixed soon. Thank you :slight_smile:
Thanks for writing in. What OS and Brave version are you on? Can you share a video of this happening?
Thanks!
yeah, here is a video that I just took of it.
I mainly noticed it when my window gets stuck on the side and I have a lot of tabs open.
I am on windows 10
Brave is up to date
Version 1.76.82 Chromium: 134.0.6998.178 (Official Build) (64-bit)
