NOTE: Any “one-liner” or topics requesting support or reporting bugs that do not make an effort to include as much of this information as possible will not be responded to. Repeatedly posting as such is grounds for banning._
Please** try to adhere to this template when reporting bugs. If you think you don’t need to fill out every section in the template fill out as much of it as you can and please be as descriptive as possible when posting.
<---------Delete this line and everything above before posting---------->**
Description of the issue: I have tried all three settings of memory saver, and no matter how long I wait, the tabs never get put to sleep. The browser is using a lot of RAM because of this.
Steps to Reproduce (add as many as necessary): 1. Turn memory saver on 2. Wait 3. Tabs don’t get put to sleep
Expected result: Tabs put to sleep, reduce RAM usage.
Reproduces how often: 24/7
Operating System and Brave Version(See the About Brave page in the main menu): Brave 1.92.134 (Official Build) (64-bit)
