Are you using the (new) [Brave Wallet] or the (old) [Crypto wallets implementation]?
Brave Wallet
Import my private key to Brave Wallet
Brave Version (check About Brave): v1.47.171
Previously I could see the balance, imported in another wallet (metamask) to check and the balance is there, even in the android version my balance appears normal. Without the balance showing, I can’t do any transactions with them on my pc browser
Grr, yep. Another scammer. Thankfully you didn’t fall for that one. I have it reported and we’ll get that account banned later.
@Aman_M would you have any thoughts here on what might be happening and how to get it showing?
@hub and @Evan123 would either of you be able to check this out.
@neroxyr Just FYI, they tend to work Monday through Friday here in USA time. Hopefully can get to you tomorrow. Just so you know, Hub and Evan123 are both staff with Brave. Then Aman_M is another User who has a lot more knowledge and experience with Wallet. I’m hoping between them all or one of the other staff, we can get this issue handled.
@neroxyr Not sure, I’m able to see my balance, sometimes it takes a while though. Maybe try to switch All networks to Polygon Mainnet on your portfolio page.
