MacOS right click on links does not open menu
When I right click a link using Brave for Macos, nothing happens. It’s supposed to open a menu that allows you to open link in a new tab, among other things. Works fine with Windows, does not work with MacOs Catalina. Using my logitech mouse, a double right click will open the menu. Using the MacBook track pad, a double right click zooms the view and does not open the contextual menu.
Hi @Sectre,
What version of Brave are you using?
Also, can you try uninstalling the logitech options?
