Listing Variable Contents on Hover in Inspector
When developing, I can’t see what a variable is in my .js file when I hover over it in the inspector
In the inspector, set a break-point somewhere in a js file and do something on the DOM that causes the debugger to stop there. Try hovering over variables. There’s not a pop-up window showing that the variable is.
The results are nothing. Nothing happens when you hover over variables.
A small window appears showing what the variable is at that point in time.
100% of the time.
Win10 - Brave v.1.1.22
I’m programming using Angularjs
Same issue with me as well Version 1.1.22 Chromium: 79.0.3945.79 (Official Build) (64-bit) on Ubuntu 18.
Hey I found that it works if you highlight the variable and hover over it. I wish you didn’t have to highlight but… that’s where we are. Hopefully, there’s a setting that I’m missing.
I’ll check it out. I am temporarily using chroma beta till this is fixed. Its bug on chromium side.
