Javascript debugger does not highlight and does not show variable values on hover
In Brave (last 2 versions at least) when I put a “debugger” inside my javascript code, the execution stop correctly but the text is “black and white” and I cannot inspect the variable values by hovering inside my code. It works fine in chromium
**Steps to Reproduce
  1. Open the dev tools on any tab
  2. Inside the console run:
     let foo='bar';
     debugger;
Actual Result:
In Brave, the code is not highlighted (black and white) and hovering the cursor on a variable shows nothing
In chromium, the code is highlighted (color) and hovering the cursor on a variable shows its value
Everytime
Brave: Version 1.2.41 Chromium: 79.0.3945.88
OS: Osx Mojave 10.14.5 (18F132)
Can you try enable remote debugging under brave://settings/privacy?
Thanks
That was fast ! Thanks you its fix my issue !
