Less payout to my wallet and remaining is missing
Briefly describe your issue:
Amount of BAT received in my Gemini wallet is lesser than actual amount I had in my Brave wallet and remaining amount (which I did not receive in my Gemini wallet) is gone.
I can’t see them in Brave wallet.
MacOS 12.2 and Brave Version 1.34.81 Chromium: 97.0.4692.99 (Official Build) (x86_64)
yes
Jan 6, 2022
yes
Are you using a VPN? (yes/no)
no
yes
@Sanjay39 Hi :slight_smile: Was just wondering if you found out any other information since you posted. If still outstanding, you might want to take a look at the two topics posted below. They have moderator responses. If this is also your issue, you might want to DM a moderator with a link to your post and include the additional information requested. Good luck!
