Briefly describe your issue:
I received less rewards to claim than actual shown on the way. What gives? I was supposed to receive 4.125 BAT but i can only claim 3.75 BAT. Last month was the same i was supposed to receive 3 BAT but instead only claimed 2.50 BAT. Can anyone from the Brave Team check on my issue? Thanks!
Windows 10 64-Bit. Brave Version 1.40.113 Chromium 103.0.5060.114 Is your browser wallet currently verified? (yes/no)
Yes What date did you verify your wallet?
20/10/2021 Have you been able to successfully receive payments in the past?
Yes Are you using a VPN? (yes/no)
No Are you in a supported region (see here for list of supported regions)?
Yes Does your device pass the SafteyNet check (Android only)?
Seems to be a common issue. I’m sure they are working on it. I was supposed to get 17.xx but ended up with 16.xx. They’ll sort it out for the next payout I am sure
How can it be estimated when its already on the way? Then Brave devs might as well don’t need to put how much worth is on its way since its estimated? It’s like you’re saying you transferred 4 BAT to another wallet and its on its way but it is estimated. Meaning if i have less than 4 BAT then the ones missing are stolen? siphoned? went to another wallet?
@Murphmeister I would say Nefarious is right. The banner X BAT arriving in Y days is not estimated. Only current earnings is estimated as some of it get rolled-over.
Yeah, I thought the whole thing about rolled-over bat is that it wasn’t reconciled. Whereas the arriving bat was reconciled (i.e. already allocated for payout).
Same here … I have not received the complete payout but then i read the brave rewards FAQs… There I read that unpaid payout would appear in the next month.
But as usual my brave rewards didn’t appear in next month also.
Receiving 2.00 instead of 2.13 is 49%?
In my opinion that would be 93,8967136%
You complain about not getting 0.13 of BAT for a whole month?
Which would be equal to (0.13 * 0.3891 = 0.050583$) 5cent.
If ±5cents/per month matters a lot to you, then you must be in serious trouble.
Just as a hint:
if you’re down by 5cent at the end of the month, it would be easier to ask some random dude for 10 cents, that would take less than 5min of “work”, but it would double your “payment” in a fraction of time without wasting your time for 30days.
When you verify Brave Rewards, your Brave Rewards balance becomes the BAT balance in your custodial account.
For example, if you have 255 BAT in your Gemini account, then if you verify Brave Rewards with a Gemini account, then you will see that 255 BAT in your Brave Rewards balance.
