Latest Brave does not work with Ubuntu Wayland
The new brave does not work. I updated the version this morning using snap and it failed to work. I reverted to the previous version to get it to work
  1. The broken version: 1.82.166 (rev 541)
  2. OS: Ubuntu 22.04 on Wayland
  3. GPU: Intel HD 520
  4. The error logs you saw (Failed to connect to Wayland display)
Same whn i run from terminal it gives me this
snap run brave
/usr/share/libdrm/amdgpu.ids: No such file or directory
[31929:31929:0911/170024.244519:ERROR:ui/ozone/platform/wayland/host/wayland_connection.cc:197] Failed to connect to Wayland display: No such file or directory (2)
[31929:31929:0911/170024.246664:ERROR:ui/ozone/platform/wayland/ozone_platform_wayland.cc:282] Failed to initialize Wayland platform
[31929:31929:0911/170024.251445:ERROR:ui/aura/env.cc:257] The platform failed to initialize. Exiting.
Desktop: Ubuntu Gnome 25.04
GPU: AMD Radeon™ Graphics
fixed it by downgrading in snap by
sudo snap revert brave
This issue only in brave snap ver 1.82.166
i faced same issue in other desktop with Intel Graphics and Ubuntu LTS 24.04
thanks for sharing the solution
Thank you for reaching out to Brave Support. This is a known issue and we’re working to resolve. Some short-term workarounds can be found below.
https://github.com/brave/brave-browser/issues/49160
If you’re running the snap version, we’ve noticed it does work if you launch via:
snap run brave --ozone-platform=x11
Kind regards,
Brave Support
