@ key not showing when input
  1. When using a keyboard with Latin Spanish configuration, when input @ key it doesn’t work
  2. I try it on other browsers (firefox, safari, chrome, Opera) and it works fine
  3. I realize it started to happen since the before last update (not the last one) the one before.
Expected result: When input shift+q on Mac it should display the @ key
Brave Version( check About Brave): Brave 1.84.135 (Build oficial) (arm64)
Chromium: 142.0.7444.135
Additional Information: If I change the keyboard config to US or any other language it works fine, only happens with Lat Spanish config
Interesting, I’m seeing this too with “Latin American - Spanish” and yes JUST the @ symbol, I to am on macos (26.1 with MacBook M3 Pro) as per your #tag, instead it’s giving quotes e.g.: “”
Further example: !"#$%&/()=
Another tag for this would be bug
I’m ALSO going to tag @Mattches to take a look.
