when I try to download a file I’m unable to do so nor can I use brave at all without having to close it using Task Manager. The “file location save” window does not display, but is seemingly there “in spirit” as I cannot click anything else in the window, change tabs or close brave by typical means. I do get the audible bell sound, alerting me that I have to click on the “active window” though it is not there. same thing seems to happen when clicking a “choose file” button to browse for a file to upload.
- right click an image.
- save image as
- stuck
can’t screenshot a window that isn’t displayed
“save as” window should appear on screen
every time I attempt to download a file. have not always had this issue. not sure what could have changed to trigger it.
Windows 10 and brave ver 0.61.52
un installing/ reinstalling would probably fix it, but I figured you guys might like to be aware of it and how to prevent it in the future.
Long Live Brave!!!
