I have a registered domain which I set to resolve to my internal ip. I am trying to setup a private network where I can access my internal site no matter where I am. I already have a VPN setup through Tailscale and everything works fine. All my sites are accessible when I’m away from the home with my VPN enabled.
The issue, however, is my sites are not reachable using Brave and only Brave. They are reachable using Chrome or dedicated apps. I’ve also done an nslookup on my Android and it correctly resolves to my internal ip. I get a response when I ping my site from my phone as well. What is preventing Brave from resolving my address?
The things I’ve tried:
- Disabled “Secure DNS” - did not work
- Enabled “Secured DNS” but chose Cloudflare as the DNS provider - did not work
- Went to brave://net-internals#dns and cleared host cache - did not work
- Went to brave://net-internals#sockets, flushed socket pools and closed idle sockets - did not work
- Cleared my browser cache - did not work
How can this issue be reproduced? You can’t because this is internal
Turned off my wifi or leave the house
Enable my VPN
Visit my internal site
Expected result: Internal site to resolve
Brave Version( check About Brave): Brave 1.83.109, Chromium 141.0.7390.55
Mobile Device details: Android 15; Build/AP3A.240905.015.A2
