Description of the issue: I use a VPN (Tailscale) to tunnel into my home network so I can access my local apps while outside of my home. When I’m external, I cannot connect to my local apps but it works fine on Chrome. Is this a bug or is there a setting that should be configured?
Leave the home so I’m not on LAN
Enable Tailscale VPN
Try to access my internal apps
Expected result: To be able to access my internal apps when external from my LAN while on VPN like I can with Chrome.
Brave Version( check About Brave): Brave 1.83.120, Chromium 141.0.7390.122
Mobile Device details: Android 16; Build/BP2A.250605.031.A3
