First, thanks for finally adding the ability to view sites in the side panel.
But it’s still very basic. With edge I used to play Spotify in the side panel, but Brave shuts the site down completely if you minimise the panel. This also means that you can’t receive message notifications or similar whe using it.
Can background processes be added? And also, can it be edited so it doesn’t force a tab on the left bar, it’s weird that it’s not independant of that.
