I have problem with cloudflare
The problem is that when I try to enter a site that uses cloudflare it doesn’t load for me, only on brave browser this happens, however when I enter the main cloudflare site I have no problem everything loads. It only happens on normal sites that use their protection.
Steps to Reproduce (add as many as necessary):1.2.3.
  1. I open a site that uses cloudflare protection.
  2. It starts to load and a black screen remains.
  3. Standing on black screen will take you a video and screenshots.
Click to view video
I have no idea why it doesn’t load I tried other browsers, but the problem is only here, if you can help me!
it’s been a week now, I thought there would be an update, possibly something from me so I waited, but now I don’t know what to do now.
Version 1.60.118 Chromium: 119.0.6045.163 (Official Build) (64-bit)
I am on windows 10
video
Can you test in private window mode, no extensions?
Yes, from any extensions. Do you have any idea from which one might be?
Maybe the VPN? but just a guess. Disable a few, then keep testing until it works. The more extensions installed the bigger the chance of problems occuring.
