Dear
I used Brave during the last summer in France and i received a lot of add and during the year i was in other country. Now i’m back in France but i don’t receive add.
Someone can help me?
Best regards
@TPMLari,
Do you have your region/locale set to FR on the device that you’re using?
Yes i have the country set on France
@TPMLari,
Can you also confirm that you’re using the most up to date version of the browser (Menu --> About Brave)? The latest release should be 1.10.95.
I seem to be having the same problem, my region is ok (Mexico), and my browser is updated, what else can i try?
I,ve been using brave for 7 days 3 hours daily and ive only got 2 ads since then.
Hope you can help, thank you
Maybe have an other thing ti help me ?
i solved the problem. So i disabled focus assist and reboot the setting of brave. After that i disable the Brave Rewards and i waited 5 min. After that i reactivate the brave rewards and i waited again 5 min. After the 5 minute i mooved my mouse and i had a notification
