Description of the issue: I disabled scripts and re-enabled them and now duckduckgo search is broken, it no longer shows
- [All] [Images][Video} [Maps][Shopping] under the search box
its basically reduced the functions to like the lite version of duckduck go but with the same higher res look, I don’t know
how to turn it back as it was before. Ah i just noticed its using HTML eg instead of it using https://duckduckgo.com/
its opening https://html.duckduckgo.com/html , not sure how to turn this off at the moment
Operating System and Brave Version(See the About Brave page in the main menu): Latest stable Brave on MX-Linux OS
