DuckDuckgo Settings Gone
Hello,Just upgraded to Brave, and using DuckDuckgo (DDG) as default browser, but i cannot find anything on obtaining the proper display of DDG with Brave: The DDG setting option is not showing?
Why?
I only have the search box, and nothing underneath (image, web, videos, currency, …) all gone out of sight, and the 3 Horizontal bars top right for setting of DDG is not here ?
Can anyone help me set this up to display DDG properly?
Using Win7 Pro x32
Thanks
@Stve,
I’ve actually seen something like this happen before. I’m on mobile right now but try reading through this thread and see if any of the information helps with your issue:
Excellent, it was the setting of Brave to set it to “all scripts allowed” and then the entire menu from DDG and its settings appeared.
Thank you for the quick fix. Appreciated.
