How to swap from solana to ethereum
I want to send fiat using ramp. Ramp seems to only use ethereum. I only have tokens that are on solana mainnet. How do I swap something from solana to ethereum so I can use ramp
Hello! If you’re attempting to add funds to your account, you can do so on Solana or Ethereum.
If you’re trying to send funds from one network to another, you’ll need to use a bridge like Wormhole. You can learn more here: https://support.brave.com/hc/en-us/articles/14601241579021-Understanding-Crypto-Networks-and-Addresses
i read the article. thank you. how do i access a bridge? the article doesnt mention that.
Here’s a list of available bridges on Solana. https://www.alchemy.com/list-of/web3-bridges-on-solana
i use jupiter, but dont know how to access bridge. Can you give any helpful tips
ok, i see how the bridge works. Its really expensive! is there a less expensive way to do this? does solana have anyway to sell get fiat and not use ethereum?
Off-ramp options into Fiat will depend on the off-ramp provider you’re using. Bridging to Ethereum is the more expensive option, due to gas costs. You can track those costs here: https://etherscan.io/gastracker
