How to fix Remember Me not working when logging into sites
Websites never remember “Remember me” or “trust this device”
  1. Login in to website and check box to remember me and/or trust this device
  2. Next visit to site requires login and/or 2FA
Sites consistently ask for 2FA and do not remain logged in
Sites do not ask for 2FA once trust this device is checked and remain logged in when “remember me” is checked
Always
Windows 11
Version 1.73.91 Chromium: 131.0.6778.85 (Official Build) (64-bit)
I have read similar threads but they are either outdated or do not work
Hello @scottodono,
It sounds like you’re experiencing persistent issues with websites not remembering your login or 2FA settings. Here are some steps to troubleshoot:
  1. Clear Browser Cache and Cookies: Corrupt cache or cookies can cause this issue.
  2. Disable Ad Blockers: Ad blockers might interfere with login settings.
  3. Check Browser Settings: Ensure settings like “Remember Me” and “Trust This Device” are enabled.
  4. Try Another Browser: Sometimes switching browsers can resolve the issue.
If the problem persists, consider reaching out to the website’s support team for further assistance.
Best Regards,
James Goff
Do I need to allow third party cookies?
@scottodono,
That may be the case, yes. If you are currently blocking all cookies, this definitely will not work afaik. I would first try setting the cookies protection in Shields to Block third party cookies. If you are still seeing the issue, try allowing all cookies and test again to see if you are still logged out.
I was actually reading your article and found some really interesting information. The thing is quite clear that I just want to thank for it. Thanks for sharing such great information, I highly appreciate your hard-working skills as the post you published have some great information which is quite beneficial for me, I hope you will post more like that in the future.
