Brave Does Not Remember Me
I have saved credentials in brave (desktop) but every time I go to a website that needs me to login, it does not remember me though it does remember the credentials. This means I need to click on the input box and then select an email and it will fill in the credentials. However, expected behavior is that it should remember my account and automatically have me logged in OR at least have credentials already filled in so i don’t need to click on the input box and select an email.
I tried allowing “All Cookies” on those pages and still not working.
Version 0.68.132 Chromium: 76.0.3809.132 (Official Build) (64-bit)
Did it happens on the same browsing session or after you quit and reopen Brave?
Did you have “Cookies” enabled for “Clear on exit” under brave://settings/clearBrowserData?
Only happens when I reopen Brave.
There is nothing ticked under “Clear on exit”
I’ve always had the same issue with each machine I run Brave on. I just assumed it’s how Brave is (the cost of using a privacy browser). I also have nothing ticked under “Clear on exit”. It’s incredibly time consuming to re-login to everything, every day. Please tell us there’s a way to fix it!
