How to enable Java Script
How can I enable Java Script for all sites? Right now it’s blocked for all sites. I can unblock an individual site, but I can’t unblock the whole internet, one by one. I would just like to enable it for everything.
Javascript is enabled by default.
If you brave://settings/shields enabled scripts, you need to disable this (otherwise it’ll cause issues also)
Unfortunately, mine doesn’t seem to be. I unblocked it for a couple of sites I use often, but I would really prefer to enable it for everything.
What scripts should I disable?
Hey @WendyL If you disable scripts in shields (see green highlight).
If failing that you could, try a clean Brave profile (for a clean start)
Oh, I think that’s it! Mine looks a bit different, but the scripts button was on. I turned it off, and now I don’t see the thing that said “Java blocked”. Thank you so much! :grinning:
